Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212вопросов Показать все
How do I remove coins pushed into the optical drive?
My four- year -old has just admitted to pushing one or more coins into the optical drive of my desk top. Is it worth using a flat knife on it to ease them out or should I remove the drive and then take it apart to get at the coins? Help!
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
Выбранное решение
It's better to remove and open the drive. These SlimLine drives are rather fragile. Pictures of a hairclip lost in a MacBook drive here. Also the work of the owners little daughter. Where would be the Mac repair business without the little ones? ;-)
Был ли этот ответ полезен?
Оценка 3
You should be fine just using this guide to remove the optical drive, after which you can simply pick out the coins with tweezers.
Оценка 2
Depending on how far in they are, you might be able to get them out with something hook-shaped. This might also help: Optical Drive Disc Removal Technique, or Foreign Object Removal
Оценка 2
Добавьте свой ответ
matt846 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 5,336
