I have Lens trouble
My camera turns on. The lens only comes out alittle bit, it beeps 3 times befor the lens goes back in.
Это хороший вопрос?
Это хороший вопрос?
i used google to find something about your problem.
and well, it's almost a common issue with a fix, i summarized the way to long fix a little bit:
connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord will start flashing and then the screen turns on and the lens retracts.
Был ли этот ответ полезен?
no work.................................
Here is a link to a troubleshooting guide. Arrow down to best solution. Hope it helps. Ralph
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 22
За всё время: 3,821
