2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580вопросов Показать все
MacBook not turning on after screen replacement. Orange light on charg
Hi,
I have a Macbook Pro Retina Late 2013 A1398 EMC 2674. I broke my retina display and replaced it with a brand new display assembly (lid, led, camera etc)
So before the display assembly replacement, The macbook was running I could see my login screen even tough the LED was broken.
I turned the Mac off, disconnected the battery and changed the display assembly.
Now for some reason its not turning on, the charger light is orange.
Thank you in advance for your answers.
Это хороший вопрос?
Оценка 1
2 Комментариев:
P.S I have tried shorting Pin 5 to ground but nothing happens, Just left it on charge for the time being and its still displaying the orange light.
из
I tried SMC and PRAM reset, the magsafe 2 charger connector went green for a short time before turning back to amber.
Still on charge at the moment, btw I forgot to mention that I am using a aftermarket charger.
Regards
из
Добавить комментарий
1 ответ
Disconnect all the connectors for backlight and picture. Then try to turn your Mac on. This should help you troubleshoot and get down to what the problem is (lcd or logic board). And I have powered on my MBP w/o a screen attached before. With connecting a monitor via hdmi, I seen mine boot to the login screen.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
mbaig будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 266
