Budget tablet with 7.00-inch 1280x800 display powered by 1.3GHz processor alongside 1GB RAM and 5-megapixel rear camera.
28вопросов Показать все
How to reset/normalised my lenovo A7-50 from speaking mode
last couple of weeks i purchase a lenovo A7-50 tablet and functiong fine but accidently i happened to select my tablet setting in speaking mode . Now whenever i tried to operate and touch the application it started speaking the moment i touch the screen now i wanted to normalized back but how to proceed? pl. i earnestly requested to invite any suggestion for normalizing .
Это хороший вопрос?
Оценка 1
3 Комментариев
I cannot find accessability on my Lenovo tablet. I cannot scroll in
settings to find it either? The talk back us horrid.
из
I m also facing same problem, i know how to disable it but I am unable to scroll down the screen on settings page
из
Please help me with the solution
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
hello thinleywangchuk99,
you waned to disable TalkBack option on your smart device
To turn off TalkBack, follow these steps:
1)Navigate to Settings > Accessibility > TalkBack.
2)Slide the TalkBack switch to the off position.
3)In the Stop Talkback dialog, select OK.
If you touch pad currnty geting malfunction you can use two fingers to select inputs
Cheers!
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
thinleywangchuk99 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 34
За всё время: 8,795
