Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630вопросов Показать все
Screen heating temperature measurements
I have done a few smartphone screen replacements, and now I'm looking at this iPad mini, and I was wondering if there is a specific temperature to heat the edges to. I have an infrared heat scanner that makes it easy to get a reading on the temp, and they are cheap and readily available, so is there a temperature range that should be applied to the screen, and other tablets and smartphones.
Это хороший вопрос?
Оценка 4
Добавить комментарий
1 ответ
Выбранное решение
I think I've heard people say generally not to go above 180F for any screen. But I think that's even a bit high. When I use my heat plate to separate LCD's, it's set to 60C(140F). Personally, for using a heat gun I go by touch to see if it's hot enough. I know it's not exact, but for me, if I can keep my finger on the screen for about 3 seconds before it burns, then I know it's perfect. I've been using that method for a couple years now, and on hundreds of screens. I would say just don't break 160-170F and you should be just fine.
Был ли этот ответ полезен?
Оценка 20
Добавьте свой ответ
srp204 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 18
За всё время: 12,923
