Gateway laptop identified by model #MT3707
Why does my gateway keep shutting down
my gateway laptop boots up then blue screens and then shuts down and repeats the cycle. i cant get into bios or anything else, what do i do to fix it?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Well it sounds like some kind of hardware has gone bad, remove the HDD and retry, then remove 1 RAM module and retry, if still the same the remove the other RAM module and replace the one you just removed, and keep going with parts that you can take off the motherboard, might try to remove the CMOS battery and try to boot and see if there is a change, let us know if you try any of these options and update us if anything helps
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
mizbooboo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 273
