The iMac G5, powered by the PowerPC G5 processor, was originally released in August 2004.
453вопросов Показать все
Вопрос закрыт
Why does boot-up fail on the grey-Apple-on-white screen?
When my iMac G5 iSight (late 2005, bought new Feb. 2006) stopped booting, it would stall on the 3rd of three white curtains coming down the screen, the one with the Apple in the middle but nothing else. I replaced the 250 GB WD hard drive with a compatible Seagate 1TB drive, which would restart once or twice during the installation process from a 10.5.6 Apple-issued installation CD (or DVD). I could then upgrade to OSX 10.5.7 and 10.5.8. But when I try a cold reboot just using the new hard drive, it fails during boot up on the same screen with the Apple. Seems like the 9-year old hard drive wasn't the problem. What is the problem?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Open it up and examine the twenty four capacitors for swelling and/or leakage. Observe the diagnostic LEDS in the center of the logic board on boot and let us know your findings.
Был ли этот ответ полезен?
Оценка 3
5 Комментариев:
Thank you, Mayer. As you often suggest, the capacitors are a problem. The motherboard is the 16-capacitor version, 820-1766-A, and two caps bulged very slightly and leaked. Also checked the Power Supply, Apple P/N 614-0378, and the 1000microfarad capacitor leaked, too. Can't report on the LED's, because when I booted with the bezel off but the display still on, I didn't see any LED's, lit or otherwise, on the MOB (saw the bright LED on the right speaker). Should I replace capacitors now, or is there some way I can find those LED's? Will they show while booting with the display removed?
из
The LEDs will show with the bezel. There are probably two CUDA buttons on the logic board to the left of the LEDs. One resets the other restarts. Jim Warholic is the definitive guy on this problem. http://jimwarholic.com/2008/07/how-to-re...
из
Thanks, I'll study that. Do you also have any advice about videos or readings about how to solder delicate electronic components? Haven't soldered much in 40 years, and I've never used non-leaded solder.
из
Spectacluar. Your prior link lead me to some advanced training by JimWarholic. Many thanks.
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 124
