The economical version of the Samsung Galaxy S4, released in July 2013.
99вопросов Показать все
Вопрос закрыт
Replace water damaged home button on S4 mini
Recently my S4 mini GTI9095 got dropped in a puddle and ever since I've been unable to get it to sleep because it constantly tries to open S Voice.
It's as if the Home Button is damaged and is somehow sending the signal it is getting pressed and activating S Voice. Is there a guide somewhere where it shows you how to replace the Home Button?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
There is not a guide yet on this site to replace the home button flex cable assembly. I am currently doing a repair on a galaxy s4 mini and will make a guide for you in the next couple days. So check back if you can wait and have no luck finding a guide on another site.
Your phone may also be experiencing this problem due to being dropped in the puddle. It may fix your problem to disassemble the phone and clean the motherboard and other parts such as the connections on the cables and any other parts with 90%+ isopropyl alcohol and a small brush like a unused toothbrush. This helps remove corrosive minerals left behind by water when it dries. If you have access to or can afford to have it cleaned with an ultrasonic cleaner than I would recommend that for the best results. If not then cleaning it with isopropyl alcohol if usually very effective as well. There are some guides on this site as well as on YouTube that can show you how to clean with isopropyl alcohol. I would try a proper cleaning and then reassemble the phone to see if the issue still exists. I will make a guide for home button replacement and maybe more guides for the s4 mini in the next few days.
Был ли этот ответ полезен?
Оценка 0
I think I will wait for the guide to be posted because I couldn't find it anywhere else. Thanks.
Оценка 0
1 Комментарий:
I have completed the guide for you so I hope it helps you out. Good luck on your repair.
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 441
