The Samsung WB150F is a 14 megapixel camera with 18x optical zoom and Wi-Fi connectivity.
14вопросов Показать все
Вопрос закрыт
How do I change the clock battery?
I hardly use my wb150f digital camera but when I tried turning it on, nothing happened. I pressed the button and the light turned red and nothing happened. I googled and found out it could be the clock memory battery. I took apart the casing and I'm a little hesitant in just pulling out the battery. I read that some batteries are soldered in. Does any one have any suggestion.
Thank you.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Arnold,
I would like to encourage you to continue pulling out the battery - for me it rather looks to be fixed with some kind of metallic clamps, not soldered.
However, at the moment I cann´t help how to remove the battery.
Instead, I am trying to solve the over exposure problem of my camera - caused by moisture. Had the lense module open in my hands but did not consentrate to the battery at that phase.
Good luck,
Asko
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 175
