Craftsman lawn tractor won't start
2002 model 917.271653 17 HP electric start, Briggs and Stratton engine. Turned key on. Heard a small pop. Won't start. Solenoid won't click. Have power to the white line to the solenoid. Checked the solenoid separately by putting power to terminals and got connectivity across power terminals. Cable to starter and cable to ground has connectivity. Jumped starter from battery and it cranks. Turn key, won't start. No solenoid click. No nothing. Any thoughts?
Update (09/02/2015)
I took the solenoid out and put power across the activating terminals by jumping from the battery. Then had conectivity across the power terminals. Checked the power cable from the solenoid terminal to the starter and the ground cable from the activation side to ground. Both good. Any ideas?
Это хороший вопрос?
15 Комментариев
That's just what mine did plus the float in mine is worn out but still works now tho it won't spark up from the spark plug I'm going to hold the wire and see if theirs any juice.
из painterinoils925
did it even try to turn over before you did this?
из Adrian Bardt
I have craftsman riding mower 16 hp Will not turn over with plug in it. If I take the plug out it will turn over
из Jeff
the solenoid that screws into the carb. It has a small 2 wire harness connecting to the solenoid. I have had issues and the following got me started and mowing. Helps if you have a buddy to help.
You can just barely pull to disconnect the wires and turn key to start. I usually have my wife crank, Ill pull wire right after she starts cranking . After it starts I connect wires back to soln./carb
из john
I need help with figuring out how come not getting fire on the other side of the terminal of the air solenoid it seems did not want to have any kind of juice on that side or the other two wires down below I can jump it across and I’ll start up and run good I want to shut off it won’t start again
из Kevin
Показать ещё 10 комментариев
