Ipad a1403 wont rotate after replaceing the glass digitizer
I recently fixed the Glass on my ipad a1403. After doing so my Ipad will not rotate. I checked the settings and the rotation lock is not on. Any suggestions?
Это хороший вопрос?
Это хороший вопрос?
There is a sensor inside that determines the orientation of the screen, it would be around the screen not on the board but attached by cable. It may have come loose during the change over.
You will have to open it again to check.
Good luck.
Был ли этот ответ полезен?
Okay thank you I will give that a try do you know where the sensor is located on the screen like a rough general location?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 165
