The Asus Padfone 2 was announced on October 16 2012 and is the successor to the Asus Padfone.
16вопросов Показать все
How can I unfreeze my tablet
My tablet is frozen what can I do
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
tresastephens, I am sure that you already tried to remove the battery for a short time and then reinsert it. Also, try a soft reset by pressing and holding the power button for +10sec. After that you can try a hard reset. This will delete all your files. Press and hold volume Down button and power on the phone.This should get you in recovery mode. Here you can select to do a factory reset by using the Volume Down key on the menu.
Был ли этот ответ полезен?
Оценка 2
Press and hold volume up and down and power button at the same time will take you to safe mode power off wait two minutes power on.
Оценка 0
Добавьте свой ответ
tresastephens будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 3,461
