Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
89вопросов Показать все
How can I get the corroded battery compartment open?
aluminum keyboard model A1314
I have tried to turn the battery compartment disc with a screw driver and a coin. It does not budge. Is there a safe way to get it off so I can get the batteries out of the keyboard?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
You could try a penetrating lubricant like WD-40. I don't think it would damage anything in the battery compartment as long as you aren't drowning the thing. Then just make sure to clean it up really well when you're done.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Michael будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 7
За последние 30 дней: 11
За всё время: 537
