The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Kenmore 110 will not power on.
Washing machine will not turn on, no selections will work. GFCI power outlet was tripped, I reset the outlet and it does have power. Tried different outlet, same result.
Is there a reset button in washer or any fuses. Made sure lid was fully closed.
Это хороший вопрос?
Оценка 6
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
If your Kenmore 110 Series Washing Machine refuses to turn on, see the Kenmore 110 Series Washing Machine Won’t Turn On problem page for possible causes and solutions.
Reading around it doesn't look like there are fuses that need to be replaced or some reset switch.
I haven't had experience with this specific washing machine, but there are some forum posts out there that look like they have had the same problem. Here's some instructions that look useful.
Good Luck!
Был ли этот ответ полезен?
Оценка 1
your forums sucks donkey dicks
Оценка 0
Добавьте свой ответ
Bob Johansen будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 19
За всё время: 4,143
