Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
Does anyone know how to tighten the hinge on this?
My xps 13 (2015) is making cracking noises along the hinge, and i think thats because the hinges are loose. Anyone know how to tighten it?
Это хороший вопрос?
Счет 8
7 Комментариев
Hi, I am having this issue as well. Could you tell me how you removed the cover?
из
I have the XPS 15, which is built very similarly. I'm also having this issue. You need a small set of torx screwdrivers to open up the back. I found a good set on amazon a while back for around $5 I think
из
The trick is to find the screw under the service tag flap
из
Anyone tried isasukexd's answer and still have this wobble?
из
The dell XPS is famous for the loose hinge, then. My XPS L321X (2012) also have the issue.
Yes, the brackets under the backplate (screwed onto the chassis) can be loose, but it's not that loose. The screw that is the loosest is the one on the display.
How to tighten that?
First, open up the cover (like you are using it)
Use your fingers, pinch the top and bottom sides of the plastic part (on the screen). Then pull toward you. (away from the screen). A plastic tab on top should reveal.
Close the screen (like you are done using it). Use your hands, gently lift up the plastic part. Antennas should be connected to it. The screws are Philips white (can be black) ones behind the display cable and the antenna.
из
Показать ещё 2 комментариев
Добавить комментарий
1 ответ
Выбранное решение
Ive fixed it! If anyone else with an XPS 13 is having this issue, take the back off and tighten any loose screws on the top left and right, where the hinge is located.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
isasukexd буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 10
За последние 30 дней: 39
За всё время: 13,049
