Выпущенный в июле 2014 года Samsung Galaxy Tab S 10.5 — это 10,5-дюймовый планшет на Android с разрешением экрана 2560x1600 пикселей, 16 ГБ встроенной памяти и 8,0-мегапиксельной камерой. Номера моделей: SM-T800 (WIFI), SM-T805 (сотовая связь и WIFI)
repair cost of my tablet?
What could be the repair cost of a galaxy tab s 10.1 inch and where canni get it fixed?
Это хороший вопрос?
Счет 0
4 Комментариев
Sir the model no. Is SM-T805. Only the screen is smashed as the touch and speakers are working perfectly fine and the screen isnworking fine. It only needs glass repair. If you can give me you ID i will email you the pictures of the current state.
из Поделиться
Haris, that would be a Tab S 10.5
из Поделиться
So what would be the price? Any idea?
из Поделиться
@200USD if you do it yourself
из Поделиться
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Haris, that is a big depends. You did not tell us what needs to be repaired. Also, not quite sure which Tab S you have. I only know the 8.4 and 10.5. Since this is an important detail, you need to clarify this
Update (09/13/2015)
That is a pretty expensive repair but it is a good tablet. I would suggest that you replace the complete screen assembly. This will be the easiest for an inexperienced repair person. The part is available at places like this. Here are the disassembly instructions ==>>Samsung-Galaxy-Tab-S_SM-T805.pdf<<== total cost around $200 USD if you do it yourself. As in where else to get it fixed, that will depend on where you are located. You can always try a internet search and see what you come up with.
Был ли этот ответ полезен?
Счет 1
HI there I have samsung tab s 10,5 sm t805 I want to replacement lcd screen my tab it is with sim card any different with that let me know please thanks
Счет 0
Hi,
For Tab S 10.5 Glass only repair costs 100 Eur.
It takes atleast 3 hours of work + 20 Eur materials.
Best regards
Счет 0
It will not charge so need where charge fixed. How much would it cost for u to fix.
Счет 0
2 Комментариев:
Can u please fix the charging part in my Samsung Galaxy tablet?
из Поделиться
It can be fixed if there is one of those problems:
1. Usb port damage
2. Battery problem (the most common problem)
3. Battery connector solder problem
4. Power IC problem
из Поделиться
Счет 0
1 Комментарий:
Once again we're back to the original question of, what kind of repair does it need? If you're talking about a screen replacement, see @oldturkey03's answer; otherwise you'll need to tell us what model number yours is and what it's doing or not doing that needs fixing.
из Поделиться
Добавьте свой ответ
Haris буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 13
За последние 30 дней: 23
За все время: 4,711
