Why is the SSD behave so poorly in the upper bay
hi there,
I wanted to replace my stock 1TB hdd (Mac Mini 2012, i7) to dual drive: HDD + SSD. When both mounted in the mini OSX wanted to format them into a fusion drive, which was not what I wanted. Therefore I unplugged the HDD and only left the SSD in an upper bay (farther from the bottom opening).
I had several problems formatting it. Installing the system took around 9 hours, after each reboot it took several mins to get rid of the "prohibition sign". Finally decided to install the yosemite using mini in target mode, then installation was a breeze.
But after booting up the Mini with this installed system i took about 15 minutes to boot. I could move mouse, drag windows but each action, each click that involved disk operations caused a minute of the "beach ball".
I decided to put the same drive, with the same system installed, onto the lower bay - the one closer to the mac mini bottom case. It launched like a rocket, system starts within 10 seconds, and is really fast.
QUESTION:
Why is this SSD so slow in the upper bay and behaves fine in the lower one? Is it possible, that the sata cable is damaged in some way? I dod not use it before. The disk, however, behaved rather normally when I used it with target mode.
Can I try to install the HDD now in the upper bay with that cable and expect it to work fine? I am little afraid mounting and dismounting the mini back and forth. Or better leave it like this, while everything is working fine?
Update (09/17/2015)
Thank you all for the replies;
DAN: really I would like to have both the SSD and the HDD connected internally in the MINI, provided that that does not slow down the machine. I mainly use Logic Pro for music creation, second drive could serve as backup and data bank then. Now I just have the HDD connected via USB 3, which is also fine. The screenshots:
the SSD, in the lower bay:
Intel 7 Series Chipset:
Vendor: Intel
Product: 7 Series Chipset
Link Speed: 6 Gigabit
Negotiated Link Speed: 6 Gigabit
Physical Interconnect: SATA
Description: AHCI Version 1.30 Supported
Crucial_CT512MX100SSD1:
Capacity: 512,11 GB (512 110 190 592 bytes)
Model: Crucial_CT512MX100SSD1
Revision: MU01
Serial Number: 1XA10E3E66FK
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk0
Medium Type: Solid State
TRIM Support: Yes
Bay Name: Lower
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Verified
Volumes:
EFI:
Capacity: 209,7 MB (209 715 200 bytes)
BSD Name: disk0s1
Content: EFI
Volume UUID: 0E371BC6-F160-3309-89CF-1C11F78AF46B
SSD:
Capacity: 511,25 GB (511 250 432 000 bytes)
Available: 357,31 GB (357 305 466 880 bytes)
Writable: Yes
File System: Journaled HFS+
BSD Name: disk0s2
Mount Point: /
Content: Apple_HFS
Volume UUID: 5111A182-F70D-3A6C-B159-AD7ABBC3DBF7
Recovery HD:
Capacity: 650 MB (650 002 432 bytes)
BSD Name: disk0s3
Content: Apple_Boot
Volume UUID: FA9BF509-0E1A-112D-95BD-0C433DC68AE6
the HDD in an external enclosure connected via USB 3:
AS2115:
Product ID: 0x1153
Vendor ID: 0x174c (ASMedia Technology Inc.)
Version: 0.01
Serial Number: 00000000000000000000
Speed: Up to 5 Gb/sec
Manufacturer: ASMedia
Location ID: 0x15100000 / 2
Current Available (mA): 900
Current Required (mA): 0
Capacity: 1 TB (1 000 204 886 016 bytes)
Removable Media: Yes
Detachable Drive: Yes
BSD Name: disk2
S.M.A.R.T. status: Not Supported
Volumes:
EFI:
BSD Name: disk2s1
Content: EFI
Volume UUID: 0E239BC6-F460-3107-89CF-1C97F78AB14B
Untitled 1:
Capacity: 999,86 GB (999 860 912 128 bytes)
Available: 776,02 GB (776 017 113 088 bytes)
Writable: Yes
BSD Name: disk2s2
Mount Point: /Volumes/Untitled 1
Content: Apple_HFS
Volume UUID: 831331D1-47B7-3DAF-840F-AA433DB3247A
Update (09/17/2015)
that's some... HGST, SATA, 5400, type TS5SAF100,. the stock drive i guess
Это хороший вопрос?
5 Комментариев
Can you give us a snapshot of the port info from the Apple menu: About Mac ... > More Info ... > System Report ... Then jump down to SATA/SATA Express under Hardware. What we need is the chipset info and the drive info for both drives. Also supply us the make & model of the SSD you are trying to install.
из Dan
Can you read off the Make & Model of your hard drive thats in the external carrier. The USB carrier won't give us access to the info.
из Dan
Here's the drives specs: TravelstarTM 5K1000
Here's the TomsHardware review: Hitachi Travelstar 5K1000 (HTS541010A9E680)
из Dan
didn't know what HGST means ;) - any idea then of what the reason of the SSD performance could be?
из adrian noryani
Sorry, for not getting back here. This drive is not an Apple spares drive which is odd (the Apple drives have their logo on the label). In its self thats not a big deal as long as the drive meets the systems requirements (which it does).
из Dan
