The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127вопросов Показать все
Xbox one controller connection issue
I recently opend up my xbox one to clean it to stop over heating while doing this i broke the wifi module antenna cable since then my controller will not contect properly i now have to use a micro usb to use my contoller does any one know of a way to fix this problem or where i can get another wifi modlue antenna cable thank you.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Same, thinking of next generation
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Would love to know if antenna swap is possible as well. All cont. updates= no fix
из
Добавьте свой ответ
Matlane будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 158
