10.1" Android tablet released in June of 2011. Samsung GT-P7510MA
107вопросов Показать все
Why wont my Tablet Charge?
My tablet wont charge I have tried everything in my eyes, turn the brightness down turn on airplane mode but it still wont charge. It still has the white lightning symbol which means its charging but the charge just decreases. Please help.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Try rebooting your device. You can do this by holding down the power button and volume button at the same time. If this doesn’t work then try carefully moving your charger around in the port to see if the port is broken or damaged. It could also be the charger. Try using different chargers in different outlets. If that doesn’t work, then you might have to take it to a repair shop.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Adithya Chittukaran будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 7
За последние 30 дней: 13
За всё время: 216
