The American Weigh AWS-100 is a small, robust scale used to make on-the-go measurements. It measures objects ranging from 0.01 grams to 100 grams.
Why is my display not working?
When is press the power button, my display never illuminates? I've replaced the batteries, but still doesn't work. What else can I try?
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi, Steven. I would make certain there is nothing obstructing your batteries and that they are in the correct slots. If you are sure the issue is not related to the battery, the most likely cause is that the display somehow got disconnected from the circuit board. Check the troubleshooting page for more info: American Weigh AWS-100 Troubleshooting
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Steven Willis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 7
За последние 30 дней: 38
За всё время: 1,488
