Why won't my DXR-5 charge?
If you are having trouble charging the DXR-5, the solution is here.
Это хороший вопрос?
Это хороший вопрос?
Using a dry cloth, clean the interior metal plates in the battery slot. Make sure the battery is touching the metal plates (terminals). Ensure that the AC adapter is properly inserted into an outlet. If the device still fails to charge, use the camera adapter to see if the unit charges. If the camera adapter works, then this implies that the AC adapter needs to be replaced. You can contact the manufacture by following this link: http://infantoptics.com/contact.php
or you can check the troubleshooting page at:
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 8,519
