An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140вопросов Показать все
Is there a wiring diagram?
I had to take my Starbuck's Barista Espresso machine apart. The problem I was having was the big handle and silver filter cup that you put the espresso grounds into, well when I would put the grounds into it and then you have to lock it in place before you start, when it was locked in place, it wasn't sitting right so, I ended up taking it all apart to clean it out thoroughly. When I put it back together, I think I got some wires put back in the wrong places because although the power light comes on, it heats up, but it's not working correctly. I just want a wiring diagram so I can make sure I get it put back together the right way.. I miss using it. Can anyone help?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Michael Renville, try this
Был ли этот ответ полезен?
Оценка 7
4 Комментариев:
Many thanks!!!!!!!!!!!!!!!!
из
Yes, this helped to put my machine back together!
из
I need to know the correct position of wires as I plug them back into the motherboard, can you show images?
из
@meanerone916 sorry but not available anymore. 7 years is a long time ;)? What are your issues with your machine?
из
Добавьте свой ответ
Michael Renville будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 29
За всё время: 1,622
