Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433вопросов Показать все
iMac startup stalling at 30%.
Hi my iMac is stalling during the startup process. Using any of the following methods the result was the same: progress bar gets to about 30% then stops progressing.
It has been left overnight in this state.
I have tried from built in HD, external usb HD and yosemite installer on thumb drive.
I have succesfully booted a macbook pro using the iMacs built in hard drive in target mode as the startup drive for the laptop.
So it does not appear to be a drive issue!
In verbose mode starting from recovery partition (on a cloned ext usb hd) it stops at:
In verbose mode starting from tested clone of internal hd it stops at:
Safe mode yields the same result.
In single user mode I can run fsck. No improvement.
Is this possibly a pram battery issue?
Это хороший вопрос?
Оценка 0
2 Комментариев
I should also note that I swapped back in my original ram just in case that was an issue but this made no difference.
I am trying to locate a copy of AHT for this machine to see if that will run of a thumb drive.
из
I am now going to look at a newer iMac and see what is supposed to happen after wifi loads in verbose mode.
из
Добавить комментарий
1 ответ
Выбранное решение
Try running AHT from the original system installation DVD.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Sadly I do not have those. Every install since and including Os 8 here but not the model specific ones for that particular machine.
из
Is there another way to run AHT on this machine apart from System install discs?
из
Добавьте свой ответ
Dickon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 8
За всё время: 121
