How do I fix the spring for the SD card?
I have to fish the SD card out of the SD slot. I am afraid that one day it will get stuck.
Это хороший вопрос?
Это хороший вопрос?
Gently remove your SD card with a pair of tweezers to avoid further damage. When you insert the memory card, does it click into place? If not, there might be something small blocking the SD card contact. Carefully turn your camera upside down to remove any loose debris. Make sure you are using the correct memory card size for your camera.
Был ли этот ответ полезен?
Make sure to check inside of the SD card well there might be something soft blocking the contact point.
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 22
За всё время: 4,630
