Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745вопросов Показать все
Greyed Out Volume Stuck On Mute
The volume button on the top of my screen is greyed out. When I use the buttons on my keyboard the volume doesn't move up or down and there is a crossed out circle under the popup. I have tried doing a PRAM reset, restarting my computer, and looking at the settings. The sound completely works when there is headphones in and there is a red light in the headphones jack. I attached a screenshot of what the volume looks like when I use the keyboard keys. Thanks in advance. UPDATE: there is no longer a red light in my headphone jack, there was about 10 minutes ago.
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
This happened to me one time.
Go to System Preferences > Sound > Output > Select "Internal Speakers" and see if that works, if it doesn't, go back to Sound > Sound Effects > change Play Sound Effects Through: "Selected Output Device" to "Internal Speakers"
Hope this helps.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
no it doesn't, everything is greyed out and unalterable in the sound area
из
i had the same problem. Through research found that it was a sensor in the headphone jack. I rebooted a few times; plugged headphones in and out a few times. Blew in compressed air. Then thought of seeing if some kind soul had written an app to take more control of sounds in a mac... found this https://staticz.com/soundcontrol/ ; installed the trial version and it fixed it inimmediately. Full disclosure: I'm an ordinary Joe user and in no way associated with the software company. i will probably wind up paying the $10 for the full version if cannot find a free alternative ;-
Оценка 1
Добавьте свой ответ
Isabell Eckard будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 18
За всё время: 10,920
