The Sanyo VPC S1275 is a 12.0 mega pixel compact digital camera produced by Sanyo which is a subsidiary of Panasonic.
memory card locked how do I fix to delete
when i go to delete my picsit says ard lockd and will not let me delete how do i fix that
Это хороший вопрос?
Счет -1
Добавить комментарий
2 Ответов
Выбранное решение
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Был ли этот ответ полезен?
Счет 2
there's several reasons which could lock the SD card
1. physical lock on side of the SD card
2. you set to lock SD card in camera
3. files on the card are locked for some reason
Счет 1
Добавьте свой ответ
genine буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 3,789
