Blown engine...
Okay, I know the sound you're talking about. I tried everything! I plugged in the lightening connecter. Plugged in headphones. Nothing helped this awful sound. It got a lot worse as time passed. When I 3D touched an app that didn't support it and the Taptic Engine made the 3 short taps, I never got the sound. By the time of writing this, the iPhone 6s Plus was doing it even then.
What I heard was a buzz, that while constant did have some come and go as far as loudness. It didn't start this way, but it was acquired with time. Over the course of having the phone for a little over a week. All down hill. The sound only happened while the phone was laying down, screen facing up.
My best words would be to really put your Taptic Engine to the test before you decide your new iPhone 6s Plus is for you.
Create a custom vibration tone for one of your contacts. Really lay on it. Have no mercy. I feel like if it's going to break, it will be during this time. Replay a few times, over a few days. You have 14 days I believe. If Apple sees your issues is covered (Mine was) then you have a year.
I can admit. I was amazed by the Taptic Engine. I 3D touched a lot of apps that didn't support it. The bumps, the tiny feedback taps had me in awe. Maybe I broke my iPhone with my child like appreciation for it. To be honest, it's very highly unlikely.
I do feel like this problem needs a bit more attention.
The lady I talked to with AppleCare had this problem earlier that day. I do have a friend who works at an Apple Retail Store. She hadn't heard of it. I believe it's a small, isolated problem only discovered by widespread means of communication. It should still be taken seriously, I mean did we blow our (Taptic) engines guys?
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
6 Комментариев
I took my 6s + to the Apple Store today and it was loud in the store, they tried to reproduce the sound but they couldn't it still sounds like something is rattling, but they may have been doing something because when they came back with my phone they said I had it on a custom vibration and I did not seems a bit weird that I would all the sudden have a " custom setting "
из Brian Williamson
I had the same issue. I am pretty good at fixing phones. I removed the screen and taptic engine device. I then placed the engine in a small container and sprayed it with WD40 and let it soak for about 10 minutes. Removed the engine, cleaned the outside, refitted and the device, placed screen gently on top and turned on device. No harsh or rattling sounds any more. Refitted the screen properly. Perfect.
из Mark
I had this same issue with my 6s+. I opened my phone up and realized that the one screw holding the Taptic device was very lose, so I tightened it and never an issue again. :)
из Landon Hall
Same issue I just got my iPhone 8 Plus this week and it dropped on the floor and ever since it has been making this noise ur describing and I can also feel it too on my screen when I scroll down and swipe anything
из saucy spice
I have this very same issue on my iPhone 8 Plus after it dropped on the floor. What should I do?
из Celio Correia
Показать 1 больше комментариев
