How do I fix Flashing?
My Palm's screen and keyboard are flashing. I've tried removing the battery and powering down but it just keeps flashing. Can this be fixed?
Это хороший вопрос?
Это хороший вопрос?
What you have done is the soft reset. Palm has 3 more types of resets.
- System or Warm reset
- Hard reset (possible removal of data from device)
- Factory reset (guaranteed removal of data from device)
Since you may loose data, I would suggest you connect the Centro to your computer & use Palm hotsync to backup your data.
The directions to do each of these resets are found on the Palm website here
http://kb.palm.com/wps/portal/kb/common/...
Try these steps & post the result (whether it worked or not) back here.
Был ли этот ответ полезен?
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 20
За всё время: 2,166
1 Комментарий
I did a hard reset on Palm Centro five times; data still there
из Chris
