4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
PSP 2000 start button does not work. help! >_<
hi! i got a problem with my psp 2000. The start button does not work. Instead i use the "ON and HOLD" switch to use the "start function". i guess its kinda unusual how that happened but it really did. I dont really know what might be the problem. the problem might be from the software or maybe from the hardware. Anyway, is there I can fix this? Its really annoying to use the method of switching to "HOLD" and then switching to "ON" just to start a game. Well thanks in advance! ^^
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Take off the case and unplug the circuit board that goes to the front buttons. Check and make sure he little nub on the start button didnt break off. Then re-insert fully and try it again. With it all off try to hit the button on the circuit board without using the actual button to see if it works.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Des Pae Cable буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 33
За всё время: 11,421
