Staples light-duty electric pencil sharpener, model no. 34462.
Sharpener keeps running even with no pencil inserted?
I have the opposite issue from a lot of people where their sharpeners won't run. Ours runs constantly, whether there's a pencil in it or not! To make it stop, we have to open the shavings drawer to release the switch that keeps the sharpener from operating when it's not there. I've tapped the sharpener vigorously and blown any shavings and debris out - everything I could see from outside the sharpener, down the bore hole and from what's accessible when the shavings drawer is removed, but it still runs continuously whenever connected to the wall plug.
I'm about to do an exploratory dissasembly, but I'm still wondering: what might be causing this? A problem with the insertion sensor? Is there anything well-known?
Это хороший вопрос?
Счет 4
1 Комментарий
I don't know, It happened at school! But, I don't know seriously.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Gregory Samson,
You are correct. issue coming from the sensor. Check the wires of sensor and This guide will help you to fix the fault your self.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Gregory Samson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 13
За последние 30 дней: 80
За всё время: 11,011
