Released in 2012, the Samsung ATIV Smart PC 500T is a 11.6", Windows-based Samsung tablet computer with 1366x768 pixel LCD, 64GB of storage capacity, and a processor capable of running up to 1.8 GHz.
My tablet and keyboard keep coming apart?
The keyboard often stops working when I'm typing
Это хороший вопрос?
Счет 0
1 Комментарий
Why Stock keyboard they tell to change keyboard layout language?
Pls. Help Me....
из
Добавить комментарий
2 Ответов
Выбранное решение
Try disconnecting and reconnecting your keyboard, making sure you place it firmly. If it’s still not working try cleaning out the keyboard connections on both the tablet and the keyboard with a dry cloth, checking for any debris, before reconnecting it.
Был ли этот ответ полезен?
Счет 0
With the tablet removed from the keyboard, push in the release button at the top of the keyboard (which you push to release the tablet) and look at the small plastic hooks on left and right they need to be both undamaged. Typically some people get frustrated and try to pull the tablet free and that breaks off one of the small hooks. If one is broken, too bad, so sad.
If both look the same and one tip or two are not broken off/damaged, then clean the contacts as suggested above and then I suggest you push down evenly when you reinsert the tablet and then sort of gently push down on left and right side top edges of the tablet to make sure the little plastic tips on the holder have best opportunity to hook onto the attaching holes in your tablet's bottom edge.
Счет 0
1 Комментарий:
My right little plastic hook thing broke when it was shipped. Is there a way to replace it?
из
Добавьте свой ответ
Marissa Santana буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 1,490
