Apple's 6th revision to the iPod Touch lineup, released in July 2015.
Вопросов 20 Показать все
Will not turn on
My iPod touch was working fine and the battery was charged well. I pushed the standby button and when I tried a few minutes later to turn it on, nothing happened. I connected it to my desktop computer and it was not recognized by the computer and still it would not turn on.
Это хороший вопрос?
Оценка 48
11 Комментариев
what if the home button does not work? how to soft reset.
из
Thank you sooooo much. You made my little girl jump out of her chair and do the happy dace.
из
My iPod will not turn on, I had put it in a safe for 2 months and after it won't charge or turn on can someone plz help
из
Jacob try leaving it on charge it might just be the battery is dead flat
из
I had this problem but I found that since updating to the latest iOS 10.1.1 I have not had this problem anymore
из
Показать 6 больше комментариев
Добавить комментарий
Ответов (11)
Выбранное решение
Have you tried a soft reset? Hold both power button and home button for 15 seconds.
Был ли этот ответ полезен?
Оценка 84
76 Комментариев:
You my sir are a life saver
из
Oh my god I love you this helped so much
из
OMG!!!! Thank you so much! I almost panicked! Thank you! Thank you! :D
из
thank you very much!!!!!!!!
из
Definitly the most helpful answer
из
Показать 71 больше комментариев
I did the soft reset for 15 seconds... It didn't work, it then tried 40 seconds and the apple logo suddenly appeared, if your iPod is uncharged a symbol showing a low battery should appear on your screen ☺️
Оценка 13
11 Комментариев:
I have often used the 15 sec tricks. Good idea to be à little bit more patient ;-) After 50 some seconds a looooow battery icon was showing. Merci !
из
Took me 40 seconds and I made sure to press down hard. Thank the lordy. Apple comes through again!
из
thanks-that really helped=made Christmas merry!
из
I finally got a low battery to show after 50 sec hold on the two buttons. How do I find someone to help replace the battery?
из
I appreciate it. Patience ended up winning out in the end on multiple units that I was told were dead. Thank you
из
If your computer doesn't recognize it then that means that your battery is probably bad.
Оценка 4
4 Комментариев:
Yer well u can't open the back so how do u no there is even a battery
из
@albert Einstein *facepalm* of course there's a battery......
из
omg you are awesome
из
thank you!!!!! you just made my day it really worked
из
If it's a 6th Gen touch it should still be under warranty. Get it back to Apple for repair or replacement.
Оценка 3
Try soft reset! This helped me today. I got up, unplugged my iPod 6th generation and was going to take it to school but I went back into my room to get it and it wouldn't turn on. I freaked out and I tried calling my mom but she didn't answer cause she was at work so I wrote on the white board saying that my iPod wouldn't turn on and my parents saw it well I was at school. When I got home I saw my case on the table with my iPad mini and my parents were yelling at me. I wanted to prove to them that I am responsible so on my iPad mini I looked up a bunch and I found this soft reset thing. (How to soft reset: hold down the home button and power button at the same time for 15 seconds.) if this doesn't work then return it, or take it to a Apple Store. Sorry for telling my story from this morning and afternoon XD
Оценка 3
Hey Galin Halimar,
So sad the soft reset didn't worked :-(
But the end of the world is not there yet!
You must replace the battery, it's probably bad.
Here's the part and the guide, stop by step 22 and work backwards.
iPod touch (6th and 7th Gen) Battery
iPod Touch 6th Generation Rear Case Replacement
Replace a battery compatible with a 6th or 7th generation iPod touch model A1574 or A2178. Part #020-00425. Battery Model #A1641. 3.83 Volts (V). Изображение
Продукт
$19.99
Оценка 3
Help!!!!!
My ipod touch 6th gen won't charge it has a blue screen when i plug it in what do I do?!?!?!?
Ps I've already tied the holding the home and on off buttons it doesn't work and I have school tomorrow and I just got it last year for my birthday.
Can someone please help me??
Оценка 1
1 Комментарий:
Also when I try to plug it into my computer it doesn't recognize my ipod
из
did a soft reset with it plugged into the computer and its back to life thanks
Оценка 0
1 Комментарий:
Thanks a lot it really worked. I did the soft reset with it plugged in.
из
U have to hold power button and home button for like 10 secs and should turn on.
Оценка 0
my ipod doesnt want turn its been 8 days keep black screen
Оценка 0
3 Комментариев:
Yeah mine has been like it for a day now
из
Mines been like that for maybe 4 to 5 months cause some guy puts his stuff on top of it and it just went black and won't turn on. I tried to connect it to my computer. I tried the soft restart. I tried everything and it still won't work. I might have to takemit to the Apple store for repairment to get it working again. And I also tried the IOS as well but no reconigization for it either.
из
And I literally just got for Christmas too
из
My iPod Touch 6th Gen was dropped in water now won’t turn on can it be fixed?
Оценка 0
1 Комментарий:
Kbrick, I don't think the Ipod 6 works if you drop it in water. Minor issues, like a few drops dripped onto it or you used a wet tissue to wash the screen is fine. But major issues probably won't end so well.
из
Добавьте свой ответ
Galen Halimar будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 9
За последние 30 дней: 37
За всё время: 71,049
