Battery life is short
Phone battery does not last as long as it should?
Это хороший вопрос?
Это хороший вопрос?
First check to make sure that your phone is not running background apps that may drain your battery life. If this is not the cause try turning off mobile data and wifi and see if this affects the battery life. Again, if this is not the root cause of the problem, a factory reset of the device can be used to clear cached memory.
Был ли этот ответ полезен?
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 362
