First released in January of 2014, the Pebble Steel is a steel-bodied Smartwatch from Pebble Technology Corporation.
7вопросов Показать все
My Pebble steel isn't vibrating when I receive a new notification
My Pebble Steel watch is not vibrating when I receive a new notification. I can still see when I get a notification because it pops up on the screen but I don't feel the vibration. I have made sure that the settings on my phone and watch are both set to vibrate for a new notification. What else can I do?
Это хороший вопрос?
Оценка 4
1 Комментарий
that fixed the problem. thanx.
из
Добавить комментарий
6 Ответов
Выбранное решение
Also, try visiting the troubleshooting page for more help.
Был ли этот ответ полезен?
Оценка 6
Наиболее полезный ответ
Mine was in Quiet Mode. You can change this in the settings. You can also change this by holding down the button on the left side of the watch while at the watch face.
Оценка 18
12 Комментариев:
Worked for me, i feel so stupid now
из
Mine was not working either, Supid #2! Thanks!!!
из
Wow! Thanks! *face palm*
из
Add me to the dummy list! Thanks for the help
из
Not working. Howwwee
из
Показать 7 больше комментариев
Try resetting the watch.
Оценка 3
3 Комментариев:
I reset it and it only vibrates on phone calls.
из
I reset mine nothing, no vibrating at all. I'll try again.
из
Though it works, feels over kill. Try the quiet mode
из
No solution worked. No vibration at all even after hard reset
Оценка 1
My pebble steel started to vibrate again, after android wear app was removed
Оценка 0
2 Комментариев:
I had same problem after installing Android Wear. I took 'belt and braces' approach and deleted AW app and also did a factory reset on the watch and signed in with a new account to make sure I really was back to 'factory settings'. I chose this boots-and-all approach as I had previously also installed a new watchface (Beacon) which screwed the watrch up completely and caused it to reboot at random times and I wanted to make sure I had totally got rid of it.
из
Thanks. I m on the top of the dummy list!!
из
Just discovered this:
Notifications will appear, but not vibrate, when the Pebble Time is charging.
Оценка 0
Добавьте свой ответ
Orlandria Heggs будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 15,577
