Samsung ST150F Smart Camera released in 2013, 16.2 MP, Silver or Black, Wifi connectivity, 25mm wide angle.
8вопросов Показать все
help troubleshoot a bad lens and what to do to fix it
i have a samsung digital camera st150f. i am having trouble with the lens on the camera. i press the on button the lens comes out for about 2 sec. and than it go's back in,then i get a message that said. the zoom did not operate normally. insert the battery again and turn the camera on. if the camera does not operate normally. do not put excessive pressure on it and contact the service center. so, can anyone tell me how to fix this or can it be fix. maybe i need to get a new lens,i do not know. can somebody help me out!! by the way i took the battery out and put it back in six times it still did the same thing.
Это хороший вопрос?
Оценка 3
Добавить комментарий
2 Ответов
I have the same problem, I have tried running a piece of paper between the lens to remove any particles that might be there but this did nothing for me.
Any help on this would be appriciated
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
same with me here. there is a speck of dust inside the camera lens. how to clean this up?
из
Remove if there is something on the way of the lenses.
Оценка 0
Добавьте свой ответ
pimpin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 555
