The Aroma ARC-914SBD rice cooker can cook from 2-8 cups of rice, steamed vegetables, meat, and even single-pot meals. The easy-to-use controls and functions of this device allow for restaurant quality food right in your very home.
Why does my rice always burn?
My rice cooker has been burning my white rice every time I use it. What is causing this and can I fix it?
Это хороший вопрос?
Счет 3
1 Комментарий
I opened my Aroma arc 914sbd and I noticed that a capacitor is burnt so i think thats the problem
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
First, be sure that you are using the white rice button. Brown rice cooks much longer, so if you push the wrong button the longer cook-time could be causing your problem. However, if your rice is burning and you are pushing the correct "white rice" button, then you may have a bad thermostat. Please see guide for Heating Element/Thermostat replacement.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Jonathan Rigby буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 926
