The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201вопросов Показать все
changing embedded sim card to change carrier from sprint to verizon
how can i change the embedded sim card from sprint to verizon or t-mobile
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
Sprint and verizon are CDMA unless its 4G LTE. You would need to flash the phone to use with another network.
Был ли этот ответ полезен?
Оценка 0
While mostly true, that's not totally true. It depends on what kind of phone you have.
Older 3G phones can be flashed from one carrier to another. Newer 4G phones such as the Sprint iPhone 6 can be unlocked to use Verizon and T-mobile, and there are still more strange combinations of unlocking such as Sprint S5 to any GSM carrier that are possible too.
There are many unlocking services, but they all depend on the original carrier of the phone, and the exact model of phone.
Contact me and I can help you unlock the phone for use with other carriers.
Оценка 0
1 Комментарий:
This response does not address the phone in question, a Samsung
model: SPH-D710
из
i would really like that info very much.. thank you.. my phone is a samsungs2 sprint model sph-d710 white phone... it only has a slot for a micro sd card. there is no slot inside the back cover or any where else on the phone.. from what i figured out it is a cdma the browser is miui home page. iv never seen miui on a phone before. model:gt-19100 android 2.3.7 ram 100 gb build number-miui-2.2.10 kernal version 2.6.35,14-g4a35117-dirty glguro@miui#1 if you could help me i would be in debt to you. thank you so much.. scott.
Оценка 0
Добавьте свой ответ
scott laxton будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 1,409
