Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
62вопросов Показать все
Can I upgrade the wireless in a PowerPC G4 Mac mini?
Want to upgrade it with a wireless card (brought use original configuration wireless was optional). Want to make sure I get the right wireless card but also get the most bang for my buck. What do you suggest?
Это хороший вопрос?
Оценка -1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
The only compatible internal wireless card is the Airport Extreme card.
If you choose to go the USB route, there are other options, but I must confess I am unfamiliar with them.
Был ли этот ответ полезен?
Оценка 1
Hi,
I have pretty much the same problem and so far I was unable to make good use of all the usb wireless dongles. Nothing seems to work...
Cheers,
Rod
Оценка 0
hi rodrigo,
you should look for an wireless dongle that is supported by your operating system or has the driver/kext for your system.
there are not that many options for you - i know that there are a few chipsets are supported by os10.
the easiest way to find something that works is the hardware list for kismac, kismac is/was a very popular wardriving program for mac computers - on their webpage are the working and not working devices for that program - if it works with kismac - it works with os 10
CLICK here
Оценка 0
Добавьте свой ответ
EndLessTinkera будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 2,545
