A popular graphic calculator released by Texas Instruments in 1996.
12вопросов Показать все
How to remove back cover?
I have a TI-83 graph calculator (not TI-83 plus), I think, by (c), it's from year 1996.
On the back cover I only see two screw (not 6 as I see here in another teardown). I have remove that 2 screw but can not remove the cover. How can I release the back cover, without broken it ? Thanks.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
At the bottom, by the data port, you can get a small screwdriver or plastic tool in the seam on both sides. Then just cautiously work your way around and toward the top; there are some snaps which will come loose.
I had the same issue with mine and got so frustrated that I just didn't care anymore if I broke it! It turns out that was the way to go.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
luisfiliperibeiro будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 4,086
