Repair information for the Huawei Ascend G7 smartphone. Released in 2014. Model numbers: G7-L01, G7-L03, G7-L11, G7-UL20.
47вопросов Показать все
Gallery does not let me share photos
Whenever i go to my gallery to try to share a picture it doesnt give me options to share it just opens another app. it opens google pic, and other downloaded apps that i have but never the share options.
Это хороший вопрос?
Оценка 2
1 Комментарий
I have an issue that i am using Quickpic gallery for my phone but i cant make it default in app>default app> quickpic i have done that but still my problem do not solve i have huawei y7 prime 2018 kindly tell me wat to do
из
Добавить комментарий
5 Ответов
Выбранное решение
I think you need to clear default app settings by going to either:
- Settings > Apps/Applications > Default Applications, and the clear all.
or
- Settings > Apps/Applications > Google+ > Clear Defaults
and redo the previous operation for Picasa and Gallery and then try sharing again.
It should give you the options to choose the app you want to use and give you the options to use same app every time or just once, select just once in order to use a different app every time.
Hope this works!
Был ли этот ответ полезен?
Оценка 3
4 Комментариев:
I fixed it, i went to app manager and i put reset app preferences thanks ✌
из
Also did the same
Settings
Apps
Manage app
Menu
Reset app preferences
из
Thanks this solved it constantly going to Whatsapp as the default; i can now choose as before. :)
из
I solved it:
•settings
•manage apps
•menu
•reset app preference
из
What App does it offer to open? An Email app maybe, by attaching the photos to a new email to share them? A social media app (Facebook, Twitter, Instagram..) and creates a new post with the pictures?
Are you trying to share the photos by text? you Gallery app doesn't have a built-in capacity to share photos to someones else's Gallery app. Sharing a photo has to be done either by email, text, bluetooth.. or any other app.
Оценка 1
5 Комментариев:
I try to share it but it opens picasa and google+ app it doesnt give me the option to pick where i want to share it. When you put share it gives you options like facebook, twitter, email, etc but it does not let me choose it, it opens google +
из
What is your current android version? and have you updated all your apps?
из
I tried everything with my Samsung S7 and I still cannot share from my gallery. When I try to it goes right back to my home screen with a quick box that says screenshot has unfortunately stopped working. Any ideas on what to do next? I rebooted it several times I've cleared cache. It just started this morning. Thanks for your help
из
I am having the same problem with my S7. Am wondering if google photos is blocking my ability to share from gallery and use their app instead?
из
I am having a similar problem with my S7. I am not able to share photos from my galary. Any time I try to share a photo, it gives me feedback that my android has unfortunately stopped.
из
I'm having the same issues, I've tried the solutions listed above and they haven't worked
Оценка 1
1 Комментарий:
Thanks so much for the time.
из
I've tried all these things and no solution. I open gallery, pick a photo, click on the share button…it hesitates, then pops up a fail notice and closes. Works fine if I remove the Facebook app from my phone.
Оценка 1
I also cannot share any photos either by fastmail or gmail. I select the photo and Send, but when the email arrives there is never an email attached. This is a key feature for me and I want to solve it.
I just noticed: it is in my Gmail Draft folder without the attachment, so the attachment is not being accessed. I have given Camera all permissions…
Оценка 0
Добавьте свой ответ
djelipsis будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 10
За последние 30 дней: 29
За всё время: 22,450
