Product released in 2011. Portable on-ear headphones that come with a detachable audio cable with built-in remote and mic for iPhone/iPod/iPad connections, and a carrying case.
22вопросов Показать все
cant get pins out to replace headband
Hello!...I am trying to replace the headband on my boys Beats Solo HD and I cant seen to get the pins out. It appeared while looking at it on vid that they actually fell out....not mine of course!.I am patient so before i go further I thought I would see if I could get help here. All is going great accept for this problem. I would be grateful if there is a way or trick to get them out. Thanks very much in advance for reading.
Это хороший вопрос?
Оценка 4
Добавить комментарий
2 Ответов
Наиболее полезный ответ
See if this guide helps: Beats Solo HD Right Hinge Pin Repair
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
It's telling me I don't have access to this link. Is the link private ?
из
Well that's not right. Can we get some help here? @kelsea
Kelsea, are you sure you wanted this job?
из
Just made it public! @mayer I'm a ride or die iFixit-er. I'll be here for the long haul. ;-)
из
Spray the pins and hinge with some lube, then tap, fairly hard with the end of a screw driver and the pins will fall out or stick out far enough to grab with tweezers.
Don't be afraid to hit it.
Оценка 0
Добавьте свой ответ
done4fun будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,774
