Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Вопрос закрыт
does not charge, does not show connection to I tune.
I fix the broken screen of I6 and put back together. worked great. I realize it was not charging keep on saying cable is not compatible. I tried this
hold the dismiss and unplug the charger and put back in. It showed charging sign but actually didn't charge. I noticed charging percentage was going down.
I connected it to computer and tried to upgrade the software, then it stuck in I tune showed the problem of -18 and later on 2001.
I have soft ware downloaded to get exit from i tune ( i phone care for Mac) and I tried to exit but it say no connection to the computer while there was connection. I got new cable from at&t store compatible with apple. again it did not help.
How to solve this. I have same problem with I 4s too.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
You might need a new charge port. Also try using a full original cable from the Apple Store.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I tried both , did not work.
из
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 77
