Replacing original HD with SSD and disk drive?
My question is more software than hardware. I have the original 500GB that is almost full. That drive has 10.10 installed. I want to replace the original and add a 240GB SSD and a 750GB disk drive. I want to create a fusion setup with these two volumes. My question is what's a good strategy to get back to my current data? Will I be able to install 10.10 from the internet (I'm not sure I want to update to 10,11)? Will I be able to restore from my time machine back up after fusing the two drives? Should I install an OS on the fusion volume and then restore from my backup?
Thanks in advance.
Это хороший вопрос?
1 Комментарий
There is really no difference between El Capitan 10.11 & Yosemite 10.10. Some apps won't run on the older Yosemite (Apples updated apps as an example). I don't think there is any reason not to go with the newer OS here. If on the other hand you had Mavericks 10.9 then you might not like some of the GUI alterations.
из DanJ
