Why PowerBook does not start with power cable connceted
Hello,
Few months back my powerbook stopped charging. I replaced the charging cable and it worked for few days. soon, it stopped charging did not boot. I took it to Mac store, they put in a charged battery and connected the power, even then the powerbook would not start. the guy there said it needs the power supply replaced. Can you help?
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Наиболее полезный ответ
You said he replaced the battery and power supply and it still would not start, and then suggested a power supply? Well obviously that won't work. First reset the SMC by removing the battery and AC adapter and holding down the start button for 10 seconds. I would remove the battery and connect the AC adapter and see if you get anything. Any lights? Any sounds?
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Good answer +
из
Добавьте свой ответ
ssrmsr буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 1,102
