Repair and disassembly guides for the Huawei Ascend G6.
no signal status and cannot connect to WIFI
suddenly my phone has no signal status even cant connect to WIFI. i tried to change sim cards with another phone but my sim card was working. also tried to put it off for a while take the sdcard and sim out but still.. no status
Это хороший вопрос?
Оценка 3
3 Комментариев
Hi,
Have you tried a factory reset on your phone? Do a backup first to save all your downloaded apps and data. Make sure your battery has a good charge before you do.
из
yes i try it but still no signal
из
Hi @totong
Try swapping SIM cards with a SIM card from a known working, same network phone to see if your SIM card works in the other phone and if the other phone's SIM card works in your phone.
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
did you mess with your phone and root it? you may have loosed your EFS
if that's not the case than proppably your antenna inside your phone has &&^&@@ itself up
you can try to replace it but i'm not 100% sure that's the antenna ..
tear it down and check inside for clear damage or rust or other junk and crap inside
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Where is the antenna, I can't find it !!! PLEASE
из
Must you use such words? Try to keep it PG.
из
Добавьте свой ответ
jrafael26 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,645
