How can I tell if its a bad U2 IC?
I replaced a lightning connector on an Iphone 5s, when I connect the charger I get an image of a black battery with a thin red line on the left centered on the screen and at the bottom of the screen an image of the lightning connector and a bolt.
This was the first connector I replaced but I've worked on several phones for other issues with no problems so I'm 95% sure it wasn't the install. The phone's owner admitted that she had been using a charge cable she bought of Groupon. She said that when it was connecting that the battery was holding a normal charge over a normal period of time.
How can I tell if is a bad connector, bad battery, or bad IC chip? I have plenty of tools but I don't know the best way to diagnose which part is the culprit. I don't want to tell her to give me more money for a battery if I'm not sure if that will resolve the issue.
Это хороший вопрос?
How long did you charge it for?
из iMedic
It was plugged in for several hours but always showed the connector icon and bolt with the empty battery
из PolishRifle
