Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
80вопросов Показать все
How do I reinstall the broadcom 802.11
at first, my newer laptop wouldnt connct to the wi fi. after doing alot of internet research on this and most sites said to uninstall it and then reinstall. i did the uninstall and downloaded a copy of the broadcom 802.11 agb and put it on a usb and then transfered it to the laptop in hopes of it reinstallng. when clickit, it extracts and than does nothing.
does anyone know a way to re install the broadcom?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
hassanalsharia,
Visit ASUS support center and type model number correctly then select OS version. you can download any driver or driver update
http://www.asus.com/support
after download the driver file run setup.exe to install driver
Restart you notebook and check whether it working in-order
Был ли этот ответ полезен?
Оценка 1
5 Комментариев:
when i did the setup and rebooted, the broadcom still does not work
из
when i did the lan broadcom installment it says i ned to insert the multi dick volume 1
из
What is the installed operating system ? did you update the OS ?
из
windows 8.1
i tried to update it but the device could not connect the internet
из
never mind it worked i installed the wireless control instead of the actual driver thanks
из
Добавьте свой ответ
hassanalsharia будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 2,141
