Acer's 15.6 inch E5-571 series laptop manufactured in 2014.
29вопросов Показать все
No optical drive means extra space?
This laptop does not have an optical drive, but it looks like it still has the cut-out on the side (See image).
I looked at some of the disassembly images, it seems like there's just some space where an optical drive would have been. I have an Xbox one wireless controller adapter which I keep connected to an usb port most of the time. The dimensions of the cut-out looks like the wireless adapter can easily fit in there.
I'm thinking of making a small slot from the opening of the optical drive cut-out where I can put the wireless adapter into when moving the laptop around.
Can anyone confirm if this can be done? Thanks in advance!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I too have a empty hole where the Blu-ray/dvd should go. I bought a internal drive for hole but thought it was a 12.7mm drive opening but found out it's a 9.5mm; so I turned the drive into a USB 3.0 external. I wouldn't mess with your controller, if you need extra USB 2.0 port just buy a hub ( I have 1 for 2.0 & 1 for 3.0). If your controller can handle 3.0 go that way (it's faster), if not then 2.0 is fast enough for your controller. I have a PS3 controller and it's USB 2.0 (fast enough).
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Daryl будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 168
