The 1st generation of the Toyota 4Runner that features a removable top .
4вопросов Показать все
Вопрос закрыт
Why is there a loud pop while going over speed bumps?
Whenever I drive over a speed bump, or go over a pothole the car makes a loud scraping pop. The sound occurs no matter what speed the bump is hit at, but does it marginally better when going over the bump diagonally. What could be causing this problem and does it need to be replaced?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Check the steering linkage under the front of the car between the tires, especially your idler arm. If anything is loose-fitting, try to fix it or replace altogether if it's beyond repair.
Check out this troubleshooting page for more information:
1984-1989 Toyota 4Runner Troubleshooting
Был ли этот ответ полезен?
Оценка 0
sound like a coilover need to be replaced
Оценка 0
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 747
