Why is my drone not flying?
It starts but won't take off?
It just flips over on the wheels and by itself it just dosent go up?
Это хороший вопрос?
Оценка 13
8 Комментариев
Mine has the same issue, its like the propellers are revered. It wont take off, it will only only push downward into the ground, its unusable!
из
I have the same issue
из
same issue anyone know why?
из
me too it just spins backwards all by itself when you take it off on the weels for a few seconds and i think it has to do with balanced weight but at the moment im still trying to figure out whats wrong
из
из
Показать 3 больше комментариев
Добавить комментарий
Ответов (12)
Наиболее полезный ответ
The proppellers are mounted in the wrong order. Switch left and right propellers front and back. Had the same problem. The drone was pushing down instead of moving up
http://blog.parrot.com/2014/07/24/how-to...
Был ли этот ответ полезен?
Оценка 6
4 Комментариев:
Hi thanks God bless you it works i thought my new drone was spoilt i came here read your started my drone and it came i recommend this to everyone IT WORKS
из
hello, thank you your suggestion works
из
Thanks a ton! UDAMAN
из
Top man. It's working now :)
из
Two propellers angle up and two angle down. Align then in a cross cross pattern so:
front left angle up - front right angle down
back left angle down - back right angle up
Оценка 4
3 Комментариев:
Thank you so much. This is exactly right!
из
OMG this was helpful!!! Thank you!!!
из
Thanks it works perfectly
из
Keep switching the propellers and trying it until you get the correct order
Оценка 2
1 Комментарий:
ok thank you
из
But I figured it out one of your PROPELLERS might be WEAKER than the other ones allowing it to be UN-EVEN. For mines that's what it is but I might need to buy new propellers if you can do that
Оценка 0
1 Комментарий:
i bought new propellers it still doesn't work
из
yes thats all it does and dont come off the grown just flips foward
Оценка 0
My drone typhoon h is not responding to the monitor
Оценка 0
My typhoon h drone camera is nor responding to the monitor
Оценка 0
No.it goes on it's side. And doesn't fly. It's not mine. It's a friends drone I was using
Оценка 0
The wings are rotating but it doesnt fly
Оценка 0
I had the same problem. I had to put the propellers on again after a crash and I just installed them on the wrong motor. Once in the right position it works like it’s supposed to. Good Luck!
Оценка 0
Check the direction of the props. They might have gotten reversed and the 2 same angle props go diagonally to each other
Оценка 0
if you press the takeoff button then try lifting up it should work
Оценка 0
1 Комментарий:
my parrot rolling spider never failed so theirs should be a priority
из
Добавьте свой ответ
Isaac Papasidero будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 6
За последние 30 дней: 45
За всё время: 17,886
